Had to replace the mfp board on this model for other issues.
But now I am unable to get papercut to install the application.
Tried clear data a couple times. Set hard drive back to installed.
I setup everything back up with manual entry. Network settings are exactly the same. Turned on Web Browser function and confirm it works.
Server and copier can communicate.
Created self sign cert. Turned ssl to admin and user mode. Turned off certificate verification. Turn on ssl for tcp socket. Turn on ssl only for openapi and set do not request and do not confirm. Rebooted when told to.
Tried latest base firmware and latest special firmware and also the firmware that was used before board change which was GG5-54. Tried all combinations of functional levels from 2.0 to 2.2
In papercut device status I get a message of:
Started (with errors) - There was an error communicating with the device. Setup will be retried at 11:59:24AM. To retry now, press "Apply" below.
Error: setApplication: error=29, message=CMS MFP Setting Check Error.
You can see the copier trying to install but gives up. You can see that papercut tries again every few seconds.
Customer has papercut 15.2 with a C258 and some E series working ok on Papercut. I also tried it on my version 16 papercut installed on my laptop and got the same error.
Using openapi 3.1+
Also tried installing Bizhub market place just to confirm an app that uses web browser would work and it installed very easily.
Using openapi 3.1+
