Minolta CF 910 error 60
  • Josh Moody
    Moodyman
    • May 2008
    • 24
    We had a machine dropped off. on pwr up it gives error code 60. any takers on what this code is
  • 10871087
    • Jan 2005
    • 1143
    if it is a C0060, here is what the book says:
    C0060
    Fusing Motor M17โ€™s failure to turn
    The M17 Lock signal is not detected for a continuous 5 sec. period or more while M17 remains energized.
    • Rudi
      • Jun 2007
      • 251
      Wow You Bring Back Memories WIth That Mach I Have Never Seen A Mach With Better Copy Quality Than The Cf 900/910 And 9001 Very Expensive To Run But A Real Master In The Art As For The Code The Fuser Drive Has Quite A Lot Of Things Against It Like Rollers And Blades Make Sure One Of Your Cleaning Blades Are Not Flipped Or Stuck And Check To See That Your Fuser Oil IS Sufficient.
