Good morning gentlemen. I have a Bizhub C360 that the NIC card when continuously pinged will cause the Copier to cycle power on & off. It also looses the IP and goes back to the generic 164.257.???/???. I'm going to replace the NIC and upgrade firmware and hopefully this will resolve the issue. Question: has anyone seen this before and I'm open to your thoughts. Thanks ahead of time.
Bizhub C360
Re: Bizhub C360
The MFPB has the NIC integrated so you will need to replace that if you think it could be that.
Have you tried to initialize the NIC?
So it goes from the Static IP back to Auto Obtain (DHCP)?
Just to be sure have u used a laptop directly connected to ping the machine with -t ?Whatever -
Re: Bizhub C360
Hello Allan, No I have not tried changing the NIC to DHCP. It's in a State of California Office and their IT did ping it continuously which caused the machine to power down then on again. What do you mean by initializing the NIC ? Most machines over the years that I've set up, I set to static and enter the IP given or generated and ping for a test, then load the correct driver, configure it and All's well. Thanks for your input ! Also on the Bizhub's I'm not an Ace !Comment
Re: Bizhub C360
Mean to say if they enter a static IP after it reboots does it go back to DHCP basically forgets the settings.
I have seen switches do this before. So ask them to connect the machine directly with a laptop and check if the machine does the same thing.
To initialize the network settings in service mode returns all the default values like protocol settings and network speed and stuff like that.
Where did the problem start. The reason for the pinging?WhateverComment
Re: Bizhub C360
The initial call was the machine was froze up, not responding at the control panel. I unplugged fax and CAT5, rebooted the copier and it worked fine as a stand alone. I went into admin network settings as it would not print and noticed it had the generic IP, not what was input by the IT dept. I got the correct IPSubnet/gateway and input those variables. I had IT ping to make sure it was on the network. We got a reply and then the copier began to cycle off power every few minutes and will not put out a print.Comment
Re: Bizhub C360
Are you sure those 2 are related?
If you leave the network unplugged will it behave?
Basically do what allan said with a laptop/crossovering directly to it and try again.I've seen machines loosing their adresses due to switches but not power cycling.I don't like the new copier I just bought. It says "put face down" but every time I do it, it blinds my eyes.Comment
Re: Bizhub C360
I'll state again, the machine unplugged from the network works GREAT ! When plugged in and a DATA PACKET hits the NIC it will cycle off power then back on again in intervals of about every minute. Also it will not put out a print. Please review ALL Above info. Thanks Guys !Comment
Re: Bizhub C360
I'll state again, the machine unplugged from the network works GREAT ! When plugged in and a DATA PACKET hits the NIC it will cycle off power then back on again in intervals of about every minute. Also it will not put out a print. Please review ALL Above info. Thanks Guys !I don't like the new copier I just bought. It says "put face down" but every time I do it, it blinds my eyes.Comment
Re: Bizhub C360
when these have a duplicate ip somewhere or a corrupt job it will keep rebooting every few minutes. thats why you need to try a laptop. if it works without network plugged in thats what i would look at first. this is common symptom on minoltas for dup ip or corrupt job.Comment
Re: Bizhub C360
I'd put the blame on "Power Over Ethernet". I've had issues with Canon devices that when on a network with "P.O.E.", the entire machine would lock up, and the control panel CPU would eventually get fried. Ethernet connections on copiers aren't designed to have a power signal run through them as well.
...We wound up making "Custom" Cat-5 cables that only had the signal wires connected, and just left the wires for running power off. It might wind up being an issue if the customer is running Gigabit Ethernet....but who needs a copier/scanner running on a GIG-E signal anyway?? 10/100 is plenty fast!!
....have fun!Comment
