Newbe with HDD problems on Bizhub C220
  • lasersc
    • May 2025
    I recently purchased a Bizhub C220, 2012 model from a government auction The hard drive had been
    removed as required before they sold it. They told me that it worked fine before the sale.
    I am trying to replace the hard drive and am having a bit
    of a problem. Here are the things that I have tried and what has happened.
    When first starting the machine without the hard I received an error, c-d004
    I went into service mode and uninstalled hard drive and the code went away.
    Printer and copier seems to work fine.
    I have tried installing two different 150gig sata drives and a 500gig sata drive.
    I have read in these forums that most any sata drive would work.
    I have tried the physical format and logical format on all of them. nothing seems to work.
    I can feel the drives spinning but it sits on 0%. I have left this process running for 24 hours.
    The code I am getting after a restart with any of these drives is an c-d411. I have tried the drives
    with out being formatted, and formatting them in different types. nothing seems to work.
    Any help would be greatly appreciated!!
  • Synthohol
    Certified Konica Expert
    • 5740
    Re: Newbe with HDD problems on Bizhub C220
    Install it in a computer and delete the partition(s) then create a single partition but do not format.
    Install in copier turn HDD to installed (it pauses for like 15 seconds so don't panic) then you can try just a logical format. If that fails you will have to do a physical format and that takes hours. When physical is done do a logical format and install the movie data if/when it asks.
    Good luck.
    • lilleputte
      • Jan 2013
      • 154
      Hitachi 250 Gig 5400RPM , always work for me. Dont have the model number ;(
      • lasersc
        Good luck.
        How is long should it take to logical format a 120 gig hard drive?
        I have followed your instructions thus far, with the exception that
        I had to do a restart after turning on the hard drive in system 2. The
        error message I am getting at start up once installed is c-d011. The format
        has been sitting on 0% for a while.
        • lasersc
          Update..... after two hours and no progress on the logical format, still
          reads 0%. Restarted unit and tried to do a physical format. Which it would
          not even let me start. The button remained blue when pressing. The drive
          was put in a computer and made simple partition with no format. I noted
          after turning on hard drive and looking at the state of drive it said "unset".
          restarted unit and came up with the C-d004. Went and looked at hard drive
          state again and it was populated with these numbers:total size 238446M and
          vacant area 0M. I couldn't make any thing of these numbers being I had a
          150 gig hard drive installed. So I am still at a loss here. Thanks for all the help
          and I am still in search of a fix.
