I've done everything by the book, but these darn things fight me tooth and nail. I can usually get up to the J6 level, no problem, but beyond that, forget it. I've disconnected the RADF and other Accessories. Tried leaving the HDD disconnected, tried replacing the Memory Chips, etc. Tried loading JUST the MFP Controller F/W for timeout issues. Nothing works.
This has happened on about 3 different machines so far, so there's got to be a fix. Some say the MFP Controller board could be at fault, but I don't wanna go down that road if I don't have to.
On one machine, I had the MFP board repaired by Hytec, but it did not fix the problem.
Has anyone had trouble with the SSD Driver boards causing this?
Thanks in advance!
Thanks in advance!
