We have a bizhub C552DS that is asking with a Yellow Triangle Exclamation Mark on a White Background "Do you wish to continue to use the destination and Job settings?" after EVERY Copy, Scan and Fax job initiated. I have never seen this before. I have looked at different settings under User and Administrator as well as reset to Factory Default the Default Copy Settings and Default Scan/Fax Settings under User Settings. I have even reset Network Setting Data, Copy Program Data and Address Registration Data in tech mode under System 1/Initialization. Where do I turn this off? Thanks in advance!
Question at End of Every Operation
It does not matter how slowly you go as long as you do not stop. –Confucius
Re: Question at End of Every Operation
Many Kyocera's do this: Are you sure? Are you sure? Are you sure?
YES! I'M SURE! =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
