I know it may seems strange that we still use this model of konica minolta.but I should tell u if u already don`t know that In third world we unfortunately still use this machine or even older.
I think many of u even don`t remember the operation procedure and technicals about minolta C-350 but I hope maybe some of u could help because I`m really desperate.
This machine was working perfectly and for some reasons I had to change the NVRAM which I dont Have access to the old one anymore.
Since I changed NVRAM with the same type of minolta C-350 the following happend:
1-At first the first print or copy jammed even before the paper pick-up
2-This machine`s setting at service mode- "marketting area" was set to Europe before and then I changed that to US and it worked.but does not produce test print in service mode and also has some other problems with size.
3-then suddenly there was this Code "C-3c30" came up for the first copy every time.
Actions taken:Changed the control board and MFP control board with the machine that the current NVRAM belonged to -entered serial number but did NOT work.
Strange thing that I have 2 minolta C-350 with exactly the same problem.
Any help will be really appreciated.
