Toner depleted bizhub c308
  • AhmedChamumi
    • May 2016
    • 130
    Helo every..recently I have installed a brand new bizhub C308, the client used it for a couple of months and it ran out of black toner they bout a new one and tried to replace it but at that time the machine had already indicated "toner depleted message" now after replacing the toner the status bar shows 100% but still the toner depleted message persist...currently the black tcr is at 6.73 and the message is persisting . I'm out of option please assist.
    Best of regards
    Ahmed Chamumi
  • Synthohol
    Certified Konica Expert
    • 5738
    Re: Toner depleted bizhub c308
    hey, if they bought aftermarket toner for it, i have no sympathy.
    get a new toner and DV unit.
    the 8 series NEEDS the extra DV in OEM toner.
    • AhmedChamumi
      • May 2016
      • 130
      Thank you...will do that
      Best of regards
      Ahmed Chamumi.
      • AhmedChamumi
        • May 2016
        • 130
        Helo there,
        Hope this finds you well, got new DV unit as well as fresh out of the box toner yesterday fixed them both and the "toner depleted" message disappeared tried multiple printouts with no problem but again rises yet another bizarre thing....all copies are coming out blank...no maintenance / error message on screen...nothing, what am i missing here pals????
        Best of regards,
        Ahmed R. Chamumi.
        • allan
          RTFM!!
          • 5459
          Only copies or internal prints as well?
          Blank prints from the engine could be many different things.
          First just reinstall the stuff.
          Whatever
          • AhmedChamumi
            • May 2016
            • 130
            Hi Allan,
            Internal prints out as well any other print jobs from computer are ok, the problem occur when you do the copying.
            • Albonline
              • Sep 2008
              • 1132
              Originally posted by AhmedChamumi
              Hi Allan,
              our machines act like that when supplies have reached end of life. are the any life counters over their limit?
              • AhmedChamumi
                • May 2016
                • 130
                No sir...the machine hasn't yield ten thousand print outs / copies as yet. it was bought just a couple of months back.
                • Albonline
                  • Sep 2008
                  • 1132
                  try running gradation adjustment, may be required to setup new imaging parts
                  • AhmedChamumi
                    • May 2016
                    • 130
                    I will get right on with it and get back to you with results
                    Best of regards,
                    Ahmed.
