Konica 7030 Print Problems
  • skeptik
    • May 2025
    Recently had to work on a Konica 7030, with an IP-011 Print Controller, and a DF-314 Document feeder.
    It copies fine.
    When you send a print job to the printer, it displays the domain username on client company's network in "*******" with the IP it came from, the file name, & amount of pages.
    This comes out in a one page format. It does not print anything else. It will continue to print a one page output for every job sent to it.
    I was told it was the wrong print controller for this copier, is there a workaround for this or could i be misinformed?
    Thanks in advance.
    Troubleshooting already done
    New drivers loaded on the Domain Controller.
    Hooked up directly to computer with CAT-5 Cable. Same result.
  • Albonline
    • Sep 2008
    • 1133
    ip011 is a gdi device. all spooling is done on server or pc sending job. so i seems the sever is not sending end of page symbol.
    • skeptik
      So if this is hooked directly to the network it wont just print jobs it has to go through the server?
      • Albonline
        • Sep 2008
        • 1133
        no jobs spool on sending pc.
        • skeptik
          I've learned that the reason it prints this way is because it was locked down by the previous administrator. No one has the password. Is there a way to reset this for the Konica 7030 w/IP-011?
          • skeptik
            I was able to get it to print from one computer on the network with administrator access, after adding it as an internet printer with local drivers. For everyone else at this company they are on limited user accounts and unable to add an internet printer, also if i log in as admin on the individual machines i can add it and it shows up as ready, but does not print, nor show anything waiting to print.
            the address i added was http://xxx.xxx.xxx.xxx:621/Print
            • pepper38_cnd
              Field Service Manager
              • Aug 2005
              • 1075
              It sounds to me like what your getting is the banner page. Go to the IP settings and turn that off. What level is the IP at and what driver are you using? The IP must be at level 3 or higher to print from XP.
              Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
              Now into Ip TV KODI Boxes
              • pepper38_cnd
                • Aug 2005
                • 1075
                The IP-011 uses an old KN card to reset remove card place the jumper marked fact or user depending on the card, install card and boot machine, after 5 minutes turn off machine remove card and put jumpper back to original position. Reinstall card and it will be at orriginal factory setting, default password "sysadm".
                • skeptik
                  It's not the banner that is disabled, and cannot be changed because i do not have the password.
                  On the Card itself i have opened it up and i can post a picture if nessecary but there are no jumpers labeled fact or user.
                  Only JP2 with 3 pins CS2 and CS1 are the labeled positions.
                  There is another set of jumpers on the opposite site of the card which labeled positions are:
                  ON OP7 (3pins)
                  ON OP5 (3pins)
                  T.B. OP4 (3pins)
                  P.A. OP3 (3pins)
                  OP2 (3pins)
                  BYPASS OP6 (2pins)
                  Test OP1 (2pins)
                  Could you provide some furhter assistance on this?
                  • pepper38_cnd
                    • Aug 2005
                    • 1075
                    Sorry my memory failed me as to which card was in that unit. Here is what you are looking for.
                    • skeptik
                      Much appreciated, about to test.
                      Thanks in advance, will get back to you either way.
                      • skeptik
                        I did this and now when I go to settings it does not give me the option to do Network config or print net config page.
                        I waitied 5-10 Min just because. same issue.
                        physically removed the card and reset it.
                        same issue. (waited some ttme again as well)
                        any ideas?
                        • pepper38_cnd
                          • Aug 2005
                          • 1075
                          Did you return the jumpers to there propper location. It may be that when the card has no settings ( factory default ) that you have to set it the first time using BootP.
                          • skeptik
                            I Reseeded the IP-011, the jumpers had already been returned to their original position.
                            I was also now able to login into the webface GUI and the default password was reset.
                            Now it shows up on the network with a network IP address but still does not show up the Directory.
                            • skeptik
                              Everything is in order. The password has been reset theres no hardware damage it copies perfectly and even pulls an IP when set as static or DHCP enabled. Both IP Settings allow me to connect it as an Internet Printer through http://the.ip.add.ress:631/Print. It works perfectly in this fashion except that limited user PC cannot add an internet printer, nor once installed as Admin will it work after switching back to the limited user account. You cannot share an Internet Printer so this work around is not even an option. Is there some simple easy to overlook thing that I may have not dug into?
