drum part code Bizhub 363
  • Bix
    • Apr 2018
    • 1421
    Hello,
    I have difficulty understanding the bizhub 363 part list. I would like to replace the drum. I went into the "Part List" and near "Drum Unit" in the Parts No. column I see the "-".
    How can I understand the code to request the order? By chance is it included in the Devoloping unit (A1UDR73000)?
  • Toxic
    • 694
    Re: drum part code Bizhub 363
    Developing unit and drum unit is not the same.
    A2A103D DR-411
    This is Europe part number for drum
    • Bix
      • Apr 2018
      • 1421
      Thank you.
      But, where are you find this information? In the part list?
      • Toxic
        • 694
        KM dealers have this information.
        We received every few months price list from KM with part numbers for consumables,accessories...
        • Synthohol
          Certified Konica Expert
          • 5740
          That's because it is not a part it is a supply and you must absolutely must replace the drum and the DV-411 developer at the same time clear the counters for drum and developer use not the developer unit developer use then run an f8 and max density and then gradations.
            • 14407
            And also replace the developer spacer rollers as they are most likely worn by now
            • Synthohol
              • 5740
              every 3rd developer change requires a new developer unit, I dont bother putting a band-aid on a broken arm.
              they run cleaner and more efficient if the PM guide is followed.
              • Woxner
                • Jul 2011
                • 829
                you can also find these type of part numbers in the spec sheetbizhub_423_363_283_223_configuration_sheet.pdf
