Xerox Altalink C8030 toner confusion
  • bryant28282000
    • Jul 2012
    • 145
    Am I correct by saying that the Xerox 7845 toner is the same as the Altalink C8030 but why is the part numbers different and the Altalink more expensive? It uses the same toner cartridge. I am confuse please help
  • hossein_electronic71
    • Jun 2015
    • 15
    Re: Xerox Altalink C8030 toner confusion
    i have too this problem.
    my machine is meters i will change to sold please help me.
    thank you
      thank you
      you have to contact xerox for that
      • Caffeine
        • 391
        Xerox (and all manufacturers) do that all the time. Sometimes they keep the same part number (75xx and 78xx and 7970) sometimes they don't.
        Although the 78xx and C80xx are most LIKELY the same toner material inside, you can't be certain. Force-feed at your own risk.
        In the past, Xerox has made small changes, like adjusting the amount of developer mixed in with the toner. Even though the toner and developer were the same in that case, the ratio was different and could cause problems.
        They may have updated the part numbers because the C80xx series is (at least on the outside) so redesigned.
          • Jun 2015
          • 15
          thank you for your respond.
          im from iran i can not connect to xerox.
          please help me.
            please help me.
            cannot help you
            not going to risk my tech ID#
            • Richard.Xerox
              • Jun 2015
              • 73
              Toner composition / Developer ratio may well have changed if the IQ problems at launch are anything to go by. The part number for the packs of developer are the same as Northwood / Spyglass though.
                • Jun 2015
                • 15
                my email address hossein_electronic71@yahoo.com
                anyone can help me.
                thanks
                • JR2ALTA
                  • Feb 2010
                  • 2033
                  If you're going to sell and service a brand without manufacturer support, Xerox would be the LAST one to try. Good luck.
                    without a tech ID# ... PWS... and support from them .. XEROX would be the LAST brand I woul try to service as an INDY TECH.
                    • Detonation
                      • Feb 2010
                      • 410
                      Pretty sure it is the same as the Metered toner has the same part number, and the Metered toners/machines are identical except for the chip.
