I don't get stumped often, in fact it has not happened for years.
This has me baffled.
A3 fed straight out of either tray of the FN no problems at all, single sided and duplex.
A3 fed to the SD unit ends up intermittently dog eared on either the front or rear leading edge corner and rolls up at the anti static brush area after the entrance rollers. It ONLY does this in the middle of larger booklets (so the stack of paper in the SD ready to be stapled and folded is quite thick) It will not do it on the first page or on thinner booklets.
leading edge curl is minimal, switching gate that changes path to SD or output trays is working fine, i pulled this area apart and saw nothing wrong.
Everything happens so quick and and random its hard to determine if the dog ear (not sharply folded) is happening at the SD unit or at the switching gate.
Anyone seen this before ?
