I have a Bizhub C3851FS that is giving a jammed paper removal message after paper has completed the paper path. I updated the firmware and this problem no longer occurs, to my knowledge, but now the MFP states that there is an open compartment when there is not one. Also the mounting plate with finisher claws makes a horrible grinding noise when going back to home position.
Bizhub 3851FS
Re: Bizhub 3851FS
if you are getting a false jam ( what code? ) check sensors for proper operation..
what has been done to it?
sounds like you have gearing probs in the finisher/exit areas.. but without error codes it will be hard to help you.
did you CLEAN the unit during the service call? ( 1st thing you should ALWAYS DO! )
life on parts?
get back to "Trouble Shooting 101" -
Re: Bizhub 3851FS
I've replaced all parts that needed to be replaced, as well as updated the firmware to get rid of machine giving false jams, but now it says that there is an open compartment when there isn't one, as well as saying there is an original on the glass when there is notComment
Re: Bizhub 3851FS
please post error log for further help.Comment
Re: Bizhub 3851FS
All I can say is something is out of sync, bound up, or broken. Those infernal finishers are not fun to take apart. Good luck!Comment
Re: Bizhub 3851FS
Assuming all the compartments are shut, (no offense, we all make mistakes)is possible either the wrong firmware got loaded? Or loaded in the wrong order? I remember having a bizhub 950 giving an open ADF message because older firmware was loaded on top of newer firmware. I'm pretty sure it's not possible to load the wrong firmware in this day and age, but those do have an odd firmware update procedure. Double check you got the right files and in the right order.
Re: Bizhub 3851FS
The finisher noise on this model is an easy fix, see page 4 of the attached pdf.
C3850FS C3851FS finisher mod.pdfComment
Re: Bizhub 3851FS
Honestly, I can't remember the order. The PDF that's listed next to the firmware on the tech support site or the manual should include the instructions. What I do remember is the firmware update wasn't like the any other Bizhub. There were 2 or 3 files in the firmware package and they stressed the order they were loaded was important.
Is this still giving an open component message?Comment
Re: Bizhub 3851FS
I have a Bizhub C3851FS that is giving a jammed paper removal message after paper has completed the paper path. I updated the firmware and this problem no longer occurs, to my knowledge, but now the MFP states that there is an open compartment when there is not one. Also the mounting plate with finisher claws makes a horrible grinding noise when going back to home position.Sad To Say I Don't Have a Life
I do this stuff on the weekends tooComment
