c654e J99-01
  • TayTayTheTechnician
    • May 2016
    • 51
    c654e J99-01
    luckily haven't spent too much time on this issue. But I have a J99-01 jam coming out of tray 3. I've read a few threads on this lovely forum and followed the advice given here but I have not been successful.
    Here are some keynotes:
    Verified SW 145 was set to 02.
    Upgraded firmware
    Jam DOES NOT happen when doing internal prints
    jams consistently,
    jam makes it all the way to the fuser
    I do get the "load correct paper size" (or something to that degree) message
    LCT guides are 100% in the correct position.
    Looked for damage to the rear connectors
    I saw people noting bad vertical transport clutches? I'm hesitant to order clutches and bill for my time because it doesn't make sense to me how clutches would cause the paper size mismatch error that I am receiving.
    Hoping that it is not board failure. Does anyone have some advice that I may have missed?
    Just trying to be a good tech for my customers.
  • Synaux
    • Mar 2012
    • 1224
    Re: c654e J99-01
    HTML Code:
    So you can go into Running Mode in Service Mode and print until you are blue in the face with no jams? If that is the case then you have some sort of I/O error....
