BizHub C300 Dried Toner Clumps on Drum
  • portside
    • Mar 2019
    • 4
    Servicing a C300 that has a line about a 1/16" buildup of dried toner on the drum, all else copies good.
    What can I use to safely remove this without damaging the drum (which is fairly new)
    Any advise will help.
  • rrrohan
    • Sep 2011
    • 1977
    Re: BizHub C300 Dried Toner Clumps on Drum
    non genuine toner to blame?
    • copyman
      Owner / Technician
      • Sep 2005
      • 4540
      99% Alcohol
      • portside
        • Mar 2019
        • 4
        Originally posted by copyman
        99% Alcohol
        thanks, will this work for the transfer belt as well?
        • copyman
          Owner / Technician
          • Sep 2005
          • 4540
          Yes you can clean transfer belt with the "99%" alcohol. Rubbing alcohol has too much water in it. After you clean Trans belt the first several prints may have some quality defects from cleaning but will go away after several pages are run.
