View Full Version : Konica Minolta C454 C9404
mearmi
09-12-2019, 11:43 PM
Konica Minolta c454 throws c94-04
doest it need the firmware to be updated?
if someone can advise what is the latest firmware and share it. Will be great help.
mearmi@hotmail.com
Synthohol
09-13-2019, 01:48 AM
check your PMs fellow contributor :)
Walterj
09-13-2019, 10:06 AM
mearmi@hotmail.com
good day
Dear
You tried to reset the error code as follows
System1 -> Initialization -> System Error Clear
Check the harness connection between the CIS and Dual scan image processing board (DSIPB). Then check between CIS and CIS Power Supply (CISPU).
Replace the CIS and check for reoccurring error.
Replace the CISPU if either fuse is OPEN and check for reoccurring error.
Check the following fuses on the CIS Power Supply (CISPU).
F1 - For 12V DC
If OPEN, replace the CISPU.
F2 - For 5V DC
If all of the above is good
Update the base fw (G00-K5)
Or the special fw (GC1-K2)
Regards
Luck
mearmi
09-17-2019, 08:51 AM
good day
Dear
F1 - For 12V DC
F2 - For 5V DC
Regards
Luck
Can I get FW GC1-K2 and does it support gmail?
Walterj
09-17-2019, 10:00 AM
good day
Dear
write to me in private
Regards
