Bizhub c25 jams
  • Anthony mazimum
    • Feb 2019
    • 9
    Bizhub c25 jams
    Why does my bizhub c25 jams when printing or photocopying colored job? It doesn't happens when printing black and white
  • blinxwap
    • Jun 2020
    • 80
    Re: Bizhub c25 jams
    Replace the separation roller ,also tighten the registration sensor actuator
    Sent from my SM-A505F using Tapatalk
    • allan
      RTFM!!
      • 5459
      Re: Bizhub c25 jams
      Does the paper leave the tray?
      Where does it jam?
      Whatever
      • Anthony mazimum
        • Feb 2019
        • 9
        Re: Bizhub c25 jams
        Where does it jam?
        It jams when coming out of the fuser
          Re: Bizhub c25 jams
          1. Where does it jam?
          2. Are you printing from same tray for B&W and color?
          3. Are you using the same type of paper for both jobs?
          I suspect you may be printing heavy color jobs and it's jamming in the fuser. You may want to increase the lead edge void.
          • allan
            RTFM!!
            • 5459
            Re: Bizhub c25 jams
            Ok great eliminates the paper tray. So the paper could be sticking to the roller.
            Does the paper leading edge make it out of the machine?
            Whatever
              Re: Bizhub c25 jams
              what paper are you using for color jobs?
              is it defined properly in the program you are printing from?
              does the print driver match the device settings?
              really need more info .. I appear to be the only 'tooth puller'
              Phil B. ' The Dentist '
              • Anthony mazimum
                • Feb 2019
                • 9
                Re: Bizhub c25 jams
                Am printing with plain A4 paper, it doesn't happen when am doing black and white copy. It only happens on color
                  Re: Bizhub c25 jams
                  Is the paper wrinkling up like an accordion?
                  I'd increase the lead edge void and go from there. You'll have to ask someone else how to do it. I'm not familar with this model.
                  • Anthony mazimum
                    • Feb 2019
                    • 9
                    Re: Bizhub c25 jams
                    No it jams at the fuser and also at the transfer roller
                      • 22943
                      Re: Bizhub c25 jams
                      Jam code? =^..^=
