J-3203 Bizhub PRO 950
  • escalante
    • Sep 2018
    • 115
    In the manual it tells me that it is a PS57 sensor. Which is marked with a red circle. Replace it with the PS57 sensor. I was not successful, I still had the same fault, then I replaced the PS8 sensor, not having much success I still had the fault. Any ideas, any suggestions are welcome.IMG-20201115-WA0000.jpg
    Enviado desde mi Infinix X656 mediante Tapatalk
  • Leyahné
    • Feb 2016
    • 44
    Re: J-3203 Bizhub PRO 950
    Please check the ICP on the ADU board.
    Sent from my SM-N960F using Tapatalk
      • 22939
      What's up with that belt tensioner? Did you wrap in in tape to attempt to tighten the belt?
      The few times that I've seen 3203 jams it was caused by a damaged fuser claw.
      • escalante
        • Sep 2018
        • 115
        Goodnight. Thank you for your comment and suggestion.
        Tell him to fix the paper jam code fault by replacing the M5 motor part code: 56AA 8011 2
