Web Browsing option
  • Kenny
    • Jun 2009
    • 522
    Web Browsing option
    hi guys,
    does anyone know what Konica Minolta machines come with web browsing options as standard?
    not having to purchase memory upgrade kits or web browsing kits?
  • Bix
    • Apr 2018
    • 1421
    Re: Web Browsing option
    Hi, web browsing is available for free from the 8 series. So also iSeries.
    Here are other multifunction printers with free browsers: Bizhub C227, Bizhub 227, Bizhub 4052 and Bizhub C3351.
    • Kenny
      • Jun 2009
      • 522
      Hello Bix,
      Will you happen to have the process of how to enable it on the 8 series machines?
      Sorry to be a pain.
      • Bix
        • Apr 2018
        • 1421
        Of course, the procedure is very simple.
        Premise: you make sure you are connected to the internet. The printer will connect to the Konica Minolta LMS server to install the browser. If you skip this step, the printer will ask you to enter the LMS code.
        How enable web browser:
        Log in to Administrator Settings - Network Settings - Web Browser - Enable. it is necessary to turn the main switch on and off in some printers.
        • Kenny
          • Jun 2009
          • 522
          Thank you for your help on this Bix, very appreciated!
          • Kenny
            • Jun 2009
            • 522
            • Synthohol
              Certified Konica Expert
              • 5803
              the copier has to have internet access first.
              check gateway and DNS.
              • Bix
                • Apr 2018
                • 1421
                Hi, connect to the internet.
                Check gateway and DNS.
                Now turn the printer off and on again. Now it should no longer ask you for your license.
                If you suspect that the customer has a strange firewall or network problem, you take your laptop and bridge the LAN port to your smartphone's wireless network.
                In this way I have solved various similar problems.
                • Kenny
                  • Jun 2009
                  • 522
                  hi guys,
                  i have 5 machines in total that require this options i have managed to enable it on 3 but 1 machine is saying deactivation is in demand, tried inputting a deactivation code into the machine but it says unable to confirm settings, and another machine just says failed to enable web browser?
                  any thoughts?
                  • Bix
                    • Apr 2018
                    • 1421
                    Hi, is the series always 8/iSeries? The procedure is the one listed above.
                    If it doesn't work, there is some problem with the network.
                    For the 4 series, optional paid options are required.
                    • Kenny
                      • Jun 2009
                      • 522
                      yes they are all 8 series machines,
                      c658 - wont enable web browser even when i try to activate it via LMS
                      c458 - wont accept deacvtivation code. Failed to register License.
                      Deactivation demand has been made for specified Serial Number.
                      • Bix
                        • Apr 2018
                        • 1421
                        Theoretically you shouldn't touch LMS. If the printer is connected to the internet, it obtains the license automatically.
                        If someone has removed the license from LMS, I believe KM intervention is needed.
                        • Kenny
                          • Jun 2009
                          • 522
                          i dont suppose you have an email i can send to them do you? not sure what their email address is for support.
                          • Kenny
                            • Jun 2009
                            • 522
                            hi guys,
                            what would stop web browser functions to be enabled on a c658 and c458
                            c458 - deactivation demand is already process WONT ACCEPT deactivation code
                            c658 - wont enable web browser, tried to activate it via lms but wont accept license code on machine. FAILED TO ENABLE tried it through service mode and administrator mode
