Freezes BIZHUB C652
  • kendo-2004
    • Mar 2021
    • 6
    Freezes BIZHUB C652
  • copier tech
    • 8105
    Re: Freezes BIZHUB C652
    Try unplugging the HDD & power on the machine?
    Failing that it is worth trying to update the firmware.
    Contact us below should you need it.
    www.copierfirmware.co.uk
    • kendo-2004
      • Mar 2021
      • 6
      I have tried to disconnect HDD. nothing is happened with the system after i powered it on again. Black screen and the nothing sounds like a common starting process.
      • copier tech
        • 8105
        Reconnect the HDD & try the firmware.
        • kendo-2004
          • Mar 2021
          • 6
          Can you recommend what exactly Firmware do i need for my machine and where to download it!
          • copier tech
            • 8105
            it is always worth updating the firmware before replacing any hardware.
            You can obtain it here:
            We can supply the latest Printer firmware & Photocopier firmware. Click Here For - Ricoh, Konica Minolta, Kyocera, Lexmark or Canon Firmware -
            • kendo-2004
              • Mar 2021
              • 6
              Now i have tried to connect another HDD, without any luck, but after that, i have taken the HDD totally and have got an error C-D004.
              But the screen buttons didn't answered.
              Does it means the NVRAM Problem or the touch panel is Brocken?
              • emujo2
                • Mar 2017
                • 1580
                Whatever the problem is you probably need a trained KM tech to move forward..Please spare me the "in my country we cannot find tech" speech This machine has got to be at least 12 years old..It's obsolete, supplies and parts are no longer available, the technology was built around XP..You are not getting a paper jam, the thing won't boot. you are wasting your time trying to repair this on your own..
                • copier tech
                  • 8105
                  Fit the original HDD back & update the firmware.
                  • kendo-2004
                    • Mar 2021
                    • 6
                    I agree with you! and I understand the old things are the old things...
