BizHub C368
  • copyman
    Owner / Technician
    • Sep 2005
    • 4544
    BizHub C368
    Hi,
    I received the following email and attachment from a customer of mine.
    Any ideas what would cause this? I've never seen it on the 4 or 8 series.
    Thanks in advance for any help
  • Hansoon
    • Sep 2007
    • 3350
    Re: BizHub C368
    That's the typical error caused by one of the latest W10 updates and the build in Windows Photo app. It has nothing to do with our machines, it's a Windows bug.
    I advise my customers to use other software to view photos such as XnView. Solved all the problems.
    XnSoft
    Hans
    “ Sent from my Intel 80286 using MS-DOS 2.0
    https://www.copytechnet.com/images/smilies/biggrin.png
    • avecosat
      • Jun 2012
      • 303
      Re: BizHub C368
      Or delete the Windows update
      • barber782
        • Aug 2011
        • 279
        Re: BizHub C368
        A windows update that was released end of March seems to have caused a few issues. There is an optional windows update that now addresses this particular issue. Just update any optional updates available. Had an issue on a 250i yesterday.
        Sent from my VTR-L09 using Tapatalk
        • copier tech
          • 8106
          Re: BizHub C368
          Originally posted by copyman
          Hi,
          This is a known issue happening across many manufacturers.
          Update the firmware & install the latest Windows updates or manually install this one.
          March 18, 2021—KB5001649 (OS Builds 19041.870 and 19042.870) Out-of-band
          • copyman
            Owner / Technician
            • Sep 2005
            • 4544
            Re: BizHub C368
            Thank you everyone!
            • REGSIS
              • May 2016
              • 434
              Re: BizHub C368
              XnSoft
              Hans
              IIRC the app is called "Photos" and when you print a jpeg from it to bizhub 226 it doesn't spool the job at all.
              If you must use it, use it just for viewing.
              • copier tech
                • 8106
                Re: BizHub C368
                As a temp fix simply use IrfanView to print jpeg files
                Windows will automatically update & resolve the issue in the coming days so you can revert to your default image viewer if required.
