Dipsw Tray 1 & 2 Thick 3 and Thick 4 enable tab
  • byronf
    Senior Member
    • Sep 2017
    • 109
    [Misc] Dipsw Tray 1 & 2 Thick 3 and Thick 4 enable tab
    Hi All,
    I am looking for the dipsw that enables the Thick.4 tab for tray 1 & 2 paper settings on E-range or 8 series.
    I recently came cross this info on the forum but for the life of it I am unable to find it now that I need it.
    Please if anybody can assist..
  • byronf
    Senior Member
    • Sep 2017
    • 109
    Re: Dipsw Tray 1 & 2 Thick 3 and Thick 4 enable tab
    Hi All,
    Last attempt for the request below.
    • Synthohol
      Certified Konica Expert
      • 5740
      It's in the service manual I believe.
      Plus why would you want to? Thick ass paper belongs on the bypass.
      You are just asking for jamming from the trays but to each their own.
        • 22946
        I don't think you're going to find that DIPSW. Tray's #1, #2, #3, #4 are only good up to 256gsm (Thick 3).
        You'll have to use the bypass for Thick 4 (257-300gsm). It's on pg C-2, C-3 of you service manual, if you'd like to read it yourself.
        • byronf
          Senior Member
          • Sep 2017
          • 109
          Hi,
          Yes I know it make no sense, however this requested by the client.
          Client has a C554e they recently up graded to C558 and back up C554e. The old C554e has the Thick 4 setting for tray 1 & 2. Now the new devices do not display this tab.
          I have compared dipsw list and still had no luck.
          • Synthohol
            • 5740
            Even the spec sheet only shows up to 256gsm for all trays except bypass.
            • tsbservice
              Field tech
              • 7926
              Originally posted by byronf
              Hi,
              Soft switch or DIPSw? You can send me saved in Excel S1 file to compare against one of mine C554e.
              • byronf
                Senior Member
                • Sep 2017
                • 109
                This is very helpful for the C558, now I need a resolution for the C554e.
                1 down 1 more to go.
                • byronf
                  Senior Member
                  • Sep 2017
                  • 109
                  I be going through Monday, will export the list.
                  • tsbservice
                    Field tech
                    • 7926
                    Synt we already cleared spec values on another hand he hava machine showing Thick 4 even that is outside of recomended range.
                    It's good to find out the answer.
