Looking for some clarification on Function levels on Bizhub Firmware levels.
  • FixitYo
    • Sep 2020
    • 15
    Firmware levels are titled with function levels in most cases, example " Subject: <Mass Production> [biz hub C4050i Series] [FW ver. G00-K8] Function Version 2.2 "
    PDF for this firmware lists different functions levels, I looked through the PDF and no mention it specifies a particular function to use with this version.
    Thanks in advance.
  • tsbservice
    Field tech
    • 8019
    Re: Looking for some clarification on Function levels on Bizhub Firmware levels.
    See under: Addition of function/ Change of specifications
    • FixitYo
      • Sep 2020
      • 15
      Thanks for the response,
      So if the functions and changes listed in the PDF does not apply to your particular situation and your just looking to update Firmware to a newer level do you have to change the function level on the machine to what's titled on the firmware version?
      • tsbservice
        Field tech
        • 8019
        Basically it depends. I mean it's not mandatory but you may experience at some point unexpected and unusual problems if function version doesn't match firmware level very rare though. I never left them unmatched but that's my understanding.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4711
          I've never messed with the function level. Just installed the latest F/W or special F/W for a specific issue.
            • 23008
            On the 4e series, a firmware change from function level 6 to function level 7 meant no more printing. That's when I learned about SW 25. =^..^=
            • occus
              • 337
              True, i had the same expirience. Very special problems in rare cases... (special behavior in ADF orientation, duplex , white sites) that's why i use the specific function level. But if you update the function level never leafe the customer without printing! Big mistake... ...
              Sometimes new drivers are needed to print. Or you go the fast way and uncheck the auto comunication checkbox, but it's not recommand.
              By the way, someone had a solution for K8 hex 30 f.l. 2.2 with airprint 2.1?
              The new License code does not work on my machines.
              โ—†Cause
              Specification(Not a bug)
              FW G00-K8 with function version2.2 supports AirPrint v2.1 .
              But, as of 1st October 2021, KMI has not got the certificate from Apple.
              Update on 19th October 2021
              KMI has got the certificate.
              [Workaround] Yes
              Set function version to 2.1(DipSW25-Hex20)
              AirPrint version will be 1.8 and it will be available because of KMI has got a certificate for AirPrint1.8
              Solution
              Because KMI has got the certificate for AirPrint2.1, we has issued the activation code below to use AirPrint2.1
              For me it sounds that should work now with K8 Hex 30.
              Has anyone successfully tested the license?
              bizhub C450i/C360i/C300i/C250i
              TRH6K2MTXTXXCMDPJ8KMRQWQMQXPX3M3
