BH-C-3110, airprint
  • Hansoon
    • Sep 2007
    • 3350
    BH-C-3110, airprint
    Anyone please have the settings needed for the BH-C-3110 to enable Airprint?
    Any soft switches to set, any special firmware?
    Hans
    “ Sent from my Intel 80286 using MS-DOS 2.0
    https://www.copytechnet.com/images/smilies/biggrin.png
  • Synthohol
    Certified Konica Expert
    • 5738
    Re: BH-C-3110, airprint
    AirPrint (Bonjour) setting is disabled
    Solution
    CAUSE: Firmware requires updating
    SOLUTION: Install the following firmware based on the model. The latest version of firmware, system software or drivers is available via One Stop Product Support.
    • bizhub C3110; A6DT30GJD01-951
    • bizhub C3100P: A6DR30GJD01-951
    • bizhub C3850/3350/3850FS; A3GN30GJ8C3-W51
    Problem
    AirPrint setting becomes invalid after updating to SMB 2.0 compatible firmware (G0C02-9AV to GGD01-950)
    Solution
    CAUSE: Firmware requires updating.
    SOLUTION: Install controller version A6DT30GJD01-951. The latest version firmware is available for download via One Stop Product Support.
    Note: Please install in the following order.
    • Controller Firmware File name [subA6DT30G0D00-899.prn]
    • Controller Firmware File name [mainA6DT30GJD01-951.prn].
    • rrrohan
      • Sep 2011
      • 1977
      • Kenny
        • Jun 2009
        • 515
        correct me if i am wrong but i believe the c3110 also requires a HDD to be able to use airprint.
