C454e - Air Print & change disk
  • xtarabash
    • Feb 2022
    • 13
    Good morning, I replaced the broken record on a Konica C454e Now the AIR PRINT function no longer works How can I recover the machine firmware? As I understand it, AIR PRINT only works with G20-J6 firmware or higher, right?
    SORRY FOR THE GOOGLE TRANSLATOR
    Dear, Agostino.
  • Max
    • Oct 2011
    • 548
    Re: C454e - Air Print & change disk
    What is a brocken record? Hdd?
    • copier tech
      • 8105
      Dear, Agostino.
      Load the latest firmware & set function version 7 with SW 25 HEX 60
      Then turn it on in Administrator Settings>Network Settings >AirPrint Settings>ON
      • Synthohol
        Certified Konica Expert
        • 5740
        PM sent.
        Thanks for being a contributor!
        • Synthohol
          • 5740
          or log on their wifi
          the mobile device has to be on the same segment of the copiers network, most customers forget that too
          • Max
            • Oct 2011
            • 548
            Don't forget Soft sw 168 set to hex 05 only then air print will be available in admin option.
            • xtarabash
              • Feb 2022
              • 13
              Yes , i'm sorry but using google traslator
              • copier tech
                • 8105
                Yes good point!
