C3110 doing mangenta dots
  • Tiagocang
    • Feb 2022
    • 62
    hey KM C3110 start doing this i test with another IU M and the dots desapear but that IU had 36% left any clue what this can be ?244526912_248930320509493_3780388712770420014_n.jpg
  • copyman
    Owner / Technician
    • Sep 2005
    • 4535
    Re: C3110 doing mangenta dots
    Originally posted by Tiagocang
    hey KM C3110 start doing this i test with another IU M and the dots desapear but that IU had 36% left any clue what this can be ?[ATTACH=CONFIG]52510[/ATTACH]
    Let me see if I understand, you put another Magenta IU in and the dots disappear and you want to know if anyone has a clue what it good be? Didn't you already answer that question when you swapped the Mag unit and dots disappeared? Bad magenta IU?
      • 22937
      The parts yield that you are basing your assumptions on is based on 4% image fill of each color. If perchance, you were printing 7% fill of magenta you would reach parts yield sooner.
      This begs the question what percentage image fill were you printing?
      There are many other factors affecting developer life:
      How many prints per run?
      How much image fill?
      How many years has the unit been in the machine?
      Are you using genuine toner?
      The short answer is: Just change the unit and stop thinking about it. Most of the factors that I've mentioned are things that you cannot affect. =^..^=
      • Tiagocang
        • Feb 2022
        • 62
        i will change it when new one arrives, just wanna know if exist any procide that i can do for this or what could do this because the IU had 36% left and maybe 2years on machine, toner is genuine , if print black its ok only colours do that sometimes with less dots
        • Toxic
          • 694
          I have this problem few times on c25,c35,c3110 and in all cases problem was high humidity or very low room temperature.
          That same bad IU works ok at summer
          • Tiagocang
            • Feb 2022
            • 62
            yh the room is kinda bad very old and this only work like 2 days for a week any advice for fix it now?
            • Toxic
              • 694
              Yes, that is the same situation like i had.
              And even if you put new IU you could expect very soon same problem.
              I assume toner and developer in IU during long standby apsorb moisture and that effect you can see as color spots on paper.
              I think only solution will be to move printer in better place with normal room temperature.
              Code:
              Operating environment
              Temperature 10°C to 30°C (50°F to 86°F) (Fluctuations of no more than 10°C (18°F) within an hour.)
              Humidity 15% to 85% (Fluctuations of no more than 10% within an hour.)
              • Drivee
                • Nov 2020
                • 322
                Replace dev section..
