Biz 4 series & scan to Gmail
  • copyman
    Owner / Technician
    • Sep 2005
    • 4538
    I've received several calls from my customers with 4 series that they can't scan to email all of a sudden. My IT guy says he thinks there are some issues with security that changed recently? Also a few customers he said he can't even see the settings.
    I know there have been some discussions on this forum but I couldn't find them. Saw some older bulletins from Kon-Min about scan to gmail, that it is supported in these old machines, etc.
    Some of these machines are in small offices and haven't been there in a long time so not sure if firmware is old, would this matter since they were scanning with no issues up until last week?
    Will the firmware that came out this year help. Last firmware before this new F/W was M1 from like 2017.
    Any suggestions I can forward to my IT guy greatly appreciated.
    Thanks in advance
  • copier tech
    • 8105
    Re: Biz 4 series & scan to Gmail
    Thanks in advance
    As you say there have been dozen & dozens of posts on this topic.
    But the simple answer is you need to turn on 2 step authentication.
    I assume your devices are the 4e series ?
    You may also need to update the firmware.
    Have a read up from this link.
    Turn on 2-Step Verification - Android - Google Account Help
    • scanmc
      • Mar 2015
      • 178
      I posted this a week or so ago. https://www.copytechnet.com/forums/k...8=#post2183986 I called Konica and they told me that nothing below the 8 series was capable of using the 2FA authentication. After several replies from from other techs I had no issue setting up this on a 4e series so I'm not sure if the Konica tech misunderstood and was thinking just the straight up 4 series. And yes the machine had the M1 version FW
      • copyman
        Owner / Technician
        • Sep 2005
        • 4538
        Thanks for replies. What if NON-E models? Will these work if Version Up firmware is used?
        Also wanted to add one of my customers with 224e B&W lost their scanning. Do I just update to latest FW from 2-22? Don't see "UP Version" procedure like the color models
        Thanks again
        • tsbservice
          Field tech
          • 7924
          Never converter ours are all 4e version but after version up firmware they should be ok I think.
          • copier tech
            • 8105
            Thanks again
            Yes update your non 'e' models to the latest firmware (currently GDR-M1.)
            And for your non 'e' use the version up firmware.
            Version Up Firmware Technical Information.pdf
            • rkamvsjj
              • Sep 2013
              • 6
              Use the App Password in the security section. works fine .
              • copyman
                Owner / Technician
                • Sep 2005
                • 4538
                [ATTACH]54364[/ATTACH]
                Thanks for the tech info sheets, few questions, It says to install GBF-M0 from 2017. There is a newer up version GR4-M0 from 2021. Should I still use the older GBF-M0 F/W as in the tech info along with GB4-A9? All these FW's are in the special firmware list on dealer website including the Movie data F/W.
                Does it matter what you posted is from UK and I'm in the USA? The instructions are different from others I've seen including not setting any soft switches?
                It states to delete movie data and replace with special movie data. I downloaded the special movie FW but where do I delete the old movie data in service mode?
                Thanks again for the help
                • techsxge
                  • Jan 2022
                  • 660
                  I think you can just install the new "special" movie data and it auto-removes the old movie data.
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4538
                    The procedure you provided in previous post worked! NON-E model now working again!
                    Only issue was with installing the new movie data. Going back with it loaded on a few different USB drives.
                    Thanks again
