Does anyone know how to set the toner indicator on the Bizhub 758/958 to 100%? I say this because on the 8 series it is done with the engine switch 34, but it doesn't work on this model. Thanks in advance.
Toner indicator 100% Bizhub 758
Re: Toner indicator 100% Bizhub 758
Check the contact pins and the toner chip. Clean it or check its surface. Make sure it is properly seated and incontact with the pins.Comment
It is not that the toner fails when I replace it, I want to know how to reset the toner without changing the bottle, as it happens in the other models, which can be used in engine 34, but in this model it is not valid.Field technician since 1994Comment
Well. I also think there is no solution to this problem. I would glad to hear for these models.Comment
