Toner indicator 100% Bizhub 758
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 302
    Does anyone know how to set the toner indicator on the Bizhub 758/958 to 100%? I say this because on the 8 series it is done with the engine switch 34, but it doesn't work on this model. Thanks in advance.
    Field technician since 1994
  • elmaligno
    • Oct 2009
    • 302
    Re: Toner indicator 100% Bizhub 758
    Anyone knows?
    • rrrohan
      • Sep 2011
      • 1977
      Engine FW DipSW 34
      • elmaligno
        • Oct 2009
        • 302
        Originally posted by rrrohan
        Engine FW DipSW 34
        • CopierNerd
          • Feb 2015
          • 207
          Check the contact pins and the toner chip. Clean it or check its surface. Make sure it is properly seated and incontact with the pins.
          • elmaligno
            • Oct 2009
            • 302
            It is not that the toner fails when I replace it, I want to know how to reset the toner without changing the bottle, as it happens in the other models, which can be used in engine 34, but in this model it is not valid.
            • CopierNerd
              • Feb 2015
              • 207
              Well. I also think there is no solution to this problem. I would glad to hear for these models.
              • allan
                RTFM!!
                • 5462
                I replace the ICP on the toner chip....
                Whatever
                • rrrohan
                  • Sep 2011
                  • 1977
                  sorry i assumed all 8 series and newer supported this
