bizhub 361 paper jam
  • Gab
    • Aug 2015
    • 664
    paper jam when making 2-sided copies , 1-sided are ok. paper jam after paper pass the fusing unit.
    In the attached file the paper jam.
    it looks like the sensor arm has displaced . i put this arm right or at least i think so, and now paper does not stops at this point but when making 2-sided copies paper exits from the machine and then machine pulls it in but when paper gets in the machine for about 10cm it stops and paper jam again . any idea?
    If i could have a picture how the sensor arm is placed i think it will help
  • Gab
    • Aug 2015
    • 664
    Re: bizhub 361 paper jam
    the paper jam picture
    • copyman
      Owner / Technician
      • Sep 2005
      • 4546
      If I remember correctly there were issues with that exit sensor breaking. You will have to get the whole fixing claw assembly because individual parts are not available. Actually with the machine being end of life with Kon/Min for a very long time I doubt you will find any parts for it at all.
      Maybe the attached doc will help you see how exit actuator is suppose to sit.
      • Gab
        • Aug 2015
        • 664
        the problem is not on the fusing unit but at inverter unit or interchange unit or whatever else they call it.
        in the attached file is this unit when paper jap happens. watch the actuator the paper hit it and stops as it shows in the file in first post.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4546
          You mentioned in original post that the actuator was out of place. From what you describe that sensor isn't working right. Make sure actuator is sitting correctly and spring is correct. That is all I can think of.
          Also not sure why you have all those red cards under your name? Perhaps make a fresh start with CTN and make a small contribution to help website. This will go a long way with getting help on this forum.
          Best of luck
          • Gab
            • Aug 2015
            • 664
            Best of luck
            as i have mentined at the original post i relocated the actuator and now i don;t have paper jam at this point. paper at 2sided copies pases the point that before have had paper jam exit from the copier and when copier pulls it in to print on the other side i have paper jam when paper re-enters about 10cm. today i will go to check the other sensor. had no time yesterday.
            what is the range of contributions?
            • Toxic
              • 695
              What is jam code?
              • kingarthur
                • 1305
                The ADU clutches always caused problems on this model, used to strip them down and clean them
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4546
                  Small contributions of $5 or $10 USD are welcome.
