New Printer Bizhub C550i screen went blank
  • cube10025@gmail.com
    • Aug 2022
    • 55
  • Synthohol
    Certified Konica Expert
    • 5740
    Re: New Printer Bizhub C550i screen went blank
    its possible the machine and type need to be set correctly boot from a firmware stick, select machine and type and make sure they arent both set to ff.
    based on the first four serial#s will determine the machine and type settings when referenced in the service manual.
    First four digits of the serial number AA7N AA7P AA7R
    [Machine] 10 10 10
    [Type] C A 0
    then i would run firmware for whatever model you trick it into thinking it is
      • Aug 2022
      • 55
      [Machine] 10 10 10
      [Type] C A 0
      Thanks for the replay, where do I edit Machine and type, do I edit files in the firmware or can I select this at the firmware install?
        • Aug 2022
        • 55
        Sorry just found it in my tech manual
