Moving User Boxes
  • kingarthur
    • 1331
    Moving User Boxes
    For those wanting to move User Boxes between devices - I've had some success using this method - doesn't seem to want to move any with any contents in
    Admin mode - Security setting- page2- Maintenance mode access - set to allow
    Service mode- System 2 - page 3 - Maintenance mode - set to effective
    an extra button pops on on the bottom left in service mode - machine update settings - select it, then machine auto update settings - machine export settings, highlight what you want to export, but from experience everything is selected, so deselect what you don't want
    enter password and start
    to import, as above, but depending on function/FW version there is a button Machine import settings - if you don't see this button, update FW and function version
    to go into maintenance mode on the i series, go to admin then security - security details - maintenance mode
    When you have finished, the device will still be in "Maintenance mode" even after rebooting - there'll be a big arrow at the top left of the screen - press it then exit
    maintenance mode
  • emujo2
    • Mar 2017
    • 1580
    Re: Moving User Boxes
    Very few customers use the box function to store documents, those that due are informed of the HDD backup utlitity and how to use it, but my techs are not responsible for the loss or movement of any stored documents. One way to move the documents is by emailing them and then uploading them onto the ne HDD or new device, but this is not something the tech should have to do (maybe a billable engagement). E
    • tsbservice
      Field tech
      • 7981
      Noted, Thanks for the tip!
