Bizhub 5000i toner empty
Re: Bizhub 5000i toner empty
4.7 Troubleshooting for Toner and Drum Problems4.7.1 New toner is not detected4.7.2 Toner cartridge cannot be recognized4.7.3 Error message prompting toner cartridge replacement does not disappear<User Check>- Check that the packaged toner cartridge is not set.- Check that a new (not used) toner cartridge is set.- Check that the genuine toner cartridge is set.<User Check>- Set the toner cartridge correctly.- Replace the toner cartridge with a new one.Step Cause Remedy 1 New toner actuator coming off Reattach the new toner actuator. 2 Connection failure of the relay front harness Reconnect the relay front harness. 3 Relay front PCB failure Replace the relay front PCB ASSY. 4 Main PCB failure Replace the main PCB ASSY. <User Check>- Check that a new (not used) toner cartridge is set.- Check that the genuine toner cartridge is set.Step Cause Remedy 1 Toner amount detection sensor PCB (light reception) failure Replace the toner amount detection sensor PCB ASSY (light reception). 2 Relay front PCB failure Replace the relay front PCB ASSY. 3 Main PCB failure Replace the main PCB ASSY. Step Cause Remedy 1 New toner actuator coming off Reattach the new toner actuator. 2 Connection failure of the relay front harness Reconnect the relay front harness. 3 Relay front PCB failure Replace the relay front PCB ASSY. 4 Main PCB failure Replace the main PCB ASSY. We know a thing or two because we've seen a thing or two.
The medication helps though... -
Open front cover. Put your finger in place where arrow down is(right of home) and wait until reset menu appears. Choose toner capacity and confirm.
If message is No toner that's another story.A tree is known by its fruit, a man by his deeds. A good deed is never lost, he who sows courtesy, reaps friendship, and he who plants kindness gathers love.
Blessed are they who can laugh at themselves, for they shall never cease to be amused.Comment
Thanks for the tips. I wasn't aware there is a New toner actuator or Toner amount detection sensor so hopefully as simple as that.
I can see the toner detect sensor PCB in the manual but not the actuator ?Last edited by copier tech; 05-01-2023, 10:26 AM.Let us eat, drink, and be merry, because tomorrow we may die!
The brother service manual has many more pages than the konica one.
The sensor is in Relay PCB ASSY inside the machine o will see the plastic actuator.
Konica 5000i i think is Brother HL-L6400
you can try this procedure to reset the toner. In this procedure the printer cannot be receiving jobs
(1)Open the front cover.
(2)Hold down the [V] ( down arrow) key for about 2 seconds.
(3)Press the key of the toner cartridge for which the counter is to be reset.
(4)Press the [Yes] key.
(5)Close the front cover.Comment
Out of curiosity, what it was?A tree is known by its fruit, a man by his deeds. A good deed is never lost, he who sows courtesy, reaps friendship, and he who plants kindness gathers love.
