View Full Version : Direct CSV import of scanner destinations
mrwho
11-22-2023, 02:37 PM
Good afternoon all.
Is there any brand/model of MFP that will allow direct import and export of address book data into .csv files without the need of proprietary software?
Thank you.
wav
11-23-2023, 10:18 PM
hi,
see this it maybe helpful
Import/Export (hp.com) (http://ftp.hp.com/pub/printers/mfps/ews_help/help/en/help_sab_ImportExport.html)
Importing the Address Book of the Machine | User Guide | IM 350, IM 430 (ricoh.com) (http://support.ricoh.com/bb_v1oi/pub_e/oi_view/0001078/0001078256/view/driver/int/0041.htm)
[SETTING MODE]|System Control|BP-70M65|09-07_021|manual download|MFP / Copier / Printer products|Office solution: Sharp (global.sharp) (https://global.sharp/restricted/products/copier/downloads/manuals/bp70m65/us/contents_09-07_021.html)
rohit34hj
01-25-2024, 10:54 AM
Since you have multiple rows of items in your file NS doesn't know if you want them all in 1 transaction or separate transactions. Since you are doing ADD here, you need to provide a Document# or ExternalID that is the same on all rows that you want grouped together onto 1 transaction. If you have auto-numbering turned on and you disallow overrides, then the Document# you import here won't actually be saved onto the transaction (because it will get an auto number instead) but the CSV importer will use the Document# to know what rows you want batched together onto the same 1 transaction.
dalewb74
01-25-2024, 06:54 PM
many of them will allow export import, but not between different brands. and some won't allow if the age difference is a few years different. i don't know of any that uses actual csv file.
slimslob
01-26-2024, 03:56 AM
I don't know about other manufactures but Ricoh has a way to convert their WIM export file to a csv file. I had to use it once for a customer who wanted to have the same address book on the their MP C3503s and on their computers that were using LAN Fax.
rohit34hj
01-31-2024, 11:54 AM
9apps apk (https://9apps.ltd/dl/)
rrrohan
04-12-2024, 07:45 AM
if you can print out the address list you can take a photo then use the excel option of import data from image
it will OCR the text and then you can make your own CSV file
Hart
04-12-2024, 08:02 AM
Sharp can do it natively on the newer units (CR4.5 at least).
Old method with proprietary format
62311
New method with standard CSV
62312
