But now is throwing a c2803 Went into the counter area and look like this code 3 different options. The count abnormality #3 is the one showing the codes Does anyone know what this is referring to?
Thats an overtoned dev unit code.. enter service mode, reset it, try to run an auto toner supply... if thats a NG then you may want to change the dev and run a tcr adjustment, should fix 'er up... whats the dev / drum count.. makes a difference too..
