Banner Printing in C6501
  • Naushad
    • Nov 2009
    • 6
    How to printing 1200mm long paper i.e banner mode in c6501, what need to done in the machine to activate banner mode in C6501
  • RRodgers
    • Jun 2009
    • 1947
    Does it has the large feed trays on the right side of the machine? I think this is only supported threw the bypass tray. Not even sure if this box supports it.
    • Naushad
      • Nov 2009
      • 6
      thank, how to print from bypass, is there anything to activate in the m/c, as when we select the paper size in b/p the max size it show is 13x19
      • Stirton.M
        All things Konica Minolta
        • Oct 2009
        • 1804
        "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
        ---Groucho Marx
        Please do not PM me for questions related to Konica Minolta hardware.
        I will not answer requests or questions there.
        Please ask in the KM forum for the benefit of others to see the question and give their input.
        • Naushad
          • Nov 2009
          • 6
          There are 2 more m/c same c6501, which is been installed in different location, they are able to print the Banner i.e 1200mm long print, but in this m/c iam not able, i want to know is there is setting which i need to do, the firmware ver is also latest i.e ver 60.
          • mabawser
            Tech
            • Sep 2009
            • 121
            As far as im aware the machine doesnt support banner printing.
            I think you may be mistaken but if you think you are correct then ask the other site how they print on banner paper.
            Just looked up paper sizes and they are the same that stirton.m has already posted.
            • Herrmann
              • Jan 2006
              • 792
              I have found an instruction regarding the 6500/5500, but it may work on the 6501 either:
              Banner printing works only with the SMART Version and with the IC408
              If a Finisher is attached, you have to remove it, inclusive disconnecting the cables.
              Then set Dipsw 10-0 to 1, and 10-1 to 0
              Enter your sheets in the bypass, adjust the paper size in the printer driver and strat printing.
              Good Luck
              If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
              • knpgazem
                • Jul 2008
                • 35
                May i ask what is the "smart version"?
                Do you mean the standard setup without all the optional finishers? or are you referring to specific firmware?
                ta
                • Herrmann
                  • Jan 2006
                  • 792
                  SMART version is with the "little" RIP ic 408, with maximum the little paper deck and copy tray or max one finisher.
                  No special firmware.
                  • adipletosu
                    hi
                    Good Luck
                    I have installed IC408
                    But in the printer setting paper size is 487 maximum lenght
                    How I can modify this?
                    And where I find settings for Dipsw? In printer adjustments?
                    • kronical
                      Kronic Copier Ninja
                      • Nov 2009
                      • 230
                      Contact your service rep. Dipsw are accessible through the tech rep mode, and incorrectly modifying these switches can cause alot of serious damage to the machine.
                      • adipletosu
                        The problem is: My service rep is not happy to help me to print on banner.
                        I spoked about this.
                        • Stirton.M
                          • Oct 2009
                          • 1804
                          OK.
                          I will reiterate ONCE more
                          Solution ID TAUS0700390EN* Solution Usage 2
                          Description
                          Is banner printing supported?
                          Solution
                          Banner printing is not supported on the bizhub PRO C5500/C5501C6500/C6500P/C6501/C6501P/C65hc. This specification cannot be changed. All product
                          change requests for this feature will be denied.
                          This pulled straight from a tech service bulletin from technical support site downloaded today.
                          ---Groucho Marx
                          • Herrmann
                            • Jan 2006
                            • 792
                            You are right with the PRO version, but not with the SMART version, as i said before... but, adipletsou, there are changes in service mode necessary, and if your tech refuses to do it, there is no chance for you. I will refuse to tell you as a non tech how to enter service mode and mess evtl. the whole mashine up.
                            • Hemlock
                              • 432
                              Then fire him. If the machine's capable of doing something and the tech is too lazy, ignorant or pigheaded to make it work, he/she needs to be put back in the shop as a setup/bench technician.
                              “Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'” (Isaac Asimov)
