Just thought I'd start a new thread for my on-going saga with the C500. For those who hadn't seen my last thread, I've got a well used C500 and I was getting a 45-20 from it. I can confirm the belt is ok, I put new dev in the dev unit's and all the dev gears look fine. Test charts were producing strong enough print but way out of reg and auto-adjust gave error 2.
I removed the sensor assy and cleaned the windows on PS8 & 9 and now the machine will start normally and even run (out of reg. copies) but when I try to do an auto colour adjust it gives the 45-01. I've tried the 25/3 software switch on and off. Had previously had a problem with the corana's blowing but they're ok now AFAIK. I should note PS9 looked like the window might have a scratch on it (hard to tell) - I think Coptech mentioned, but can the window be popped off or replaced?
One other thing I'm trying to confirm is how to do the manual adjust - after the chart is printed I put it on the platen and hit 'scan' on the touch screen but nothing happens
I can go to the 'copy screen' and hit start but thought that can't be right?
Any help greatly appreciated
