KM reoccuring C3913 code
  • racefreak
    • Sep 2010
    • 30
    [Error Code] KM reoccuring C3913 code
    I've got a code 3913 that keeps popping up. I've checked dip 3-1 to a 0 and it is already there. The machine will warm up as normal but when you try to run it, it codes out after about 3 seconds. No paper in the fuser, just coming out out the PF unit. All the book and Knowledgebase says is "fuser not set" . Has anyone else seen this issue?
  • racefreak
    • Sep 2010
    • 30
    Figured out what was causing the problem. The Connectors for the fusing unit had compressed pins in it. After removing the fuser and manually spreading each pin, the machine came to ready and ran with no problem. In I/O mode 25-4 you can watch the state of the fuser set change states.
    • bernyb
      • 42
      Good for you. I always love it when I fix something just by trying something different.
      • mrwho
        Major Asshole!
        • 4299
        Re: KM reoccuring C3913 code
        Good evening.
        Sorry for hijacking this thread, but it's 8PM and my head is about to explode.
        I'm having this same error: replaced the fusing unit's connectors, dismantled the back of the machine to check the machine side connectors, swapped the ADU rails between them to compensate for downward torsion (caused by age - the adu belly was scrapping the machine, now it closes fine) and I even considered the chance of the rail swapping be the cause for the error, so I repaired the old connectors and manually connected them to the back of the machine while checking IO 25-4 to see if it would give me a 1, without success.
        I'm thinking of a blown fuse, but before starting to dig around the machine for a blown ICP, I've checked the ICP list, and there isn't any on the list said to cause this error.
        Anyone else had this problem caused by a blown ICP? If so, which one or at least where should I look for it? If not, what else can cause this besides the obvious culprits?
        Thanks!
        Mascan42
        Ibid
        • Mick01
          • Nov 2012
          • 362
          Hi,
          You have checked just about everything that i would recommend for this issue.
          I had a faulty relay on the AC driver board once that was causing this issue. apart from that the Printer control board could also be the likey culprit.
          Good luck and hope this helps.
          • mrwho
            Major Asshole!
            • 4299
            I made a gross mistake last friday (talk about working overtime frying your brains): I tested the connectors one at a time instead of placing both at the same time - when I placed both old connectors in the back the IO check gave me back the 1 - so back to the rails hypothesis.
            I'm swapping back the rails to the original position and I've already ordered new ones. I'll keep you posted!
            Thanks!
            Mascan42
            Ibid
            • tulintron
              • Jul 2014
              • 669
              Good evening.
              Thanks!
              What equipment model?
              • tulintron
                • Jul 2014
                • 669
                In series C5500 / C6500 and C5501 / C6501 this FUSING NOT SET message is just bad lock ADU. I resolve I open and close tightly.
                Closing ADU very carefully, because bad connection.
                No DIPSW and without ICP. Just opening and closing.
                • swaggen
                  • Sep 2017
                  • 100
                  Thanks!
                  What ended up solving this issue for you?
