I'm running legal size pressure prices through ny 1050 EP, Duplex.
On the front side, I just started getting some repeating patterns - mostly, but not exclusively on bold text.
Edit : Just noticed that I actually have the same problem on both sies of the sheet. Not so obvious on the second side becuase there's no bolt text.....
The pattern doesnlt repeat across the whole width - just a section about 1" wide on the left and round about the same on the right of the page
The first repeat happens on text that is 2.75" from the top of the page and it repeats first about 1" below the original and then again 9.25" below the orginal. Space between repeats is 8.625"
The same thing happens on an original piece about 6.5" from the top of the sheet and it repeats about 1" below the original. No second repeat on this one.
I've been running ths job consistently for about three days now - variable data but very similar patterns from piece to piece.
Any ideas on cause and solution will be gratefully received.
Thanx in advance,
Doug
Thanx in advance,
Doug
