COPY QUALITY
  • gansathya
    • Jul 2010
    • 45
    [Misc] COPY QUALITY
    Hi friends,
    i had a copy quality problem with kyocera mita km5035,
    when i installed the machine the copy was great, after 5000 copies copy quality getting down, i cleaned the transfer charge roller and primary assembly, and dev unit. And also done the drum refresh but its not giving good quality what i need to do kindly help me friends
  • LNorris
    • Sep 2008
    • 645
    What do the internal prints look like?
    • gansathya
      • Jul 2010
      • 45
      its so light, and black filling is not that much of good .
      • LNorris
        • Sep 2008
        • 645
        Try the charge grid or drum
          • 23007
          Do you have a scan of the problem image?
          • gansathya
            • Jul 2010
            • 45
            Hi,
            No
            • CCS
              • 266
              are you using oem kyocera toner or a generic toner ?
              • taskalfaman
                • Nov 2009
                • 137
                check if the right toner is installed!!! ask for the box, check the toner gears, and coupling
                make some black copies
                preform sim 130
                if not ok=> change dev.
                have fun
                • T911
                  • Jun 2007
                  • 628
                  TASKALFAMAN-do the new 5500i and 5550ci have hypass. and how bout the 255/305. thanks t
                  • taskalfaman
                    • Nov 2009
                    • 137
                    yes , all hypass compat.
                    • T911
                      • Jun 2007
                      • 628
                      U sure about the 255/305.
                      • taskalfaman
                        • Nov 2009
                        • 137
                        what are the numbers( type) for the european market?
