Hi all, I have a 950 fitted with a FS618 (I think) which says empty fns tray after a certain amount of stapled sets have exited. I understand this is a restriction of the finisher but is there a dipswitch I can set to turn this restriction off? Thanks in advance.....
BZ950 fns exit tray restriction when stapling
Re: BZ950 fns exit tray restriction when stapling
Had a inter-territorial sale get lost because of this issue. There are bit switch settings, but only 3. One setting turns them off and large runs fall on floor. one is the default which only allows so many stapled sheets. and one that would stop at so many sheets then you unload tray, and it resumes. KM says the drive gears can't handle a big load. go engineers!
