Konica Bizhub 7145 horizontal streaks on 11X17
  • Calfella
    • May 2025
    [Misc] Konica Bizhub 7145 horizontal streaks on 11X17
    Hi all,
    I have a bizhub 7145 that started to have several streaks on the long side of the sheet near the middle. I've taken out the drum unit and cleaned of the cleaning blade and most of the streaks dissappeared except for one faint one in the middle. What else can it be coming from? thanks. Meter has 107,000.
  • BIG PAPA
    Da Boss
    • 234
    Re: Konica Bizhub 7145 horizontal streaks on 11X17
    Lines? Either Corona unit, fuser, drum/blade, residue in path? Can you attach a sample?
    sigpic
    • Calfella
      Here is what it looks like . . . sometimes it gets lighter or darker as each sheet goes by.
      • pepper38_cnd
        Field Service Manager
        • Aug 2005
        • 1075
        Sure looks like a dirty charge wire to me. Change the wires.
        Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
        Now into Ip TV KODI Boxes
        • copytechman
          • Nov 2008
          • 926
          I concur with Pepper!
          Regards!
          A.
          • Calfella
            Is that typical for these wires at less thatn 100K clicks? Just ordered a pack of 10.
            • KM7155
              • Aug 2008
              • 145
              if u wan to confirm whether is the wire problem, just increase the charge voltage in service mode.
              sometimes the charging corona is the culprit.
