Ok any opinions help here I am getting stumped.
I have this bizhub 421 installed with an IC-207 and no hdd just a compact flash.
It is in a large school environment with a lot of other machines but no Konicas. The problem is it just stops printing. It worked good for a year and now it doesn't want to print anymore. I can still ping the machine, I can still email out I just can't get the job to even show up at the printer it stays at the computer.
Twice I have changed the IP address to something else and had this problem resolved for a month. Then the problem comes back. When it comes back it is worse and worse. Locks up more often and more often. When it locks up it is locked up pretty bad to the point where I have to really wait to even be able to hook my laptop up to print to it. ***When I do get it going though I can print fine with my laptop (no lock ups) Then as soon as I plug the machine into their network it goes right back to locking up immediately. I understand this IT guys point of view that all of his other machines are working fine but I am in a tough spot here I can't seem to figure out why this won't print on his network and why changing the ip address is fixing it for a little?
steps I have taken:
Firmware
Drivers
Port setting (both LPR/RAW)
Swapped OACB (with NIC port embedded on it) from a known good machine
Swapped Compact Flash Cards
Swapped Print Controller...
I haven't done the PRCB but it seems to me that wouldn't be anything to do with it if changing IP address's is the only time we see change?
any help is appreciated....
steps I have taken:
Firmware
Drivers
