C280 black dropping out
  • sauce_boss
    • Oct 2011
    • 26
    Black color dropping out in the middle of copy runs. Seems to be getting worse last time I was there black was almost never visible. Have tried replacing the black drum, transfer roller, transfer belt, and most recently the HV board per Konica. The next step is the black developer unit per Konica. Anyone seen this or have any other ideas?
  • wal
    Re: C280 black dropping out
    The problem is with the clutch (CL6) on the rear drive assy. You can order just the clutch or the whole assembly
    • Dougtech
      • Apr 2011
      • 113
      I am suprised they didn't do developer second. Does it differ on the amount of fill on the copies?
      What is the page count? Developer is supposed to run 570,000 for black.
      Pull out black developer and spin by hand, is it bound up at all? you can compare to a color DV.
      Could be clutch like wal said too.
      • jarwil
        • Jun 2009
        • 61
        I'm with Wal on this one.
        Had similar and ended up being the dev clutch. Suprised if it isn't the clutch.
        • sauce_boss
          • Oct 2011
          • 26
          Machine only has 188k on it, Dev isn't binding at all. I am going to try the clutch before the black dev and see what happens.
          • jarwil
            • Jun 2009
            • 61
            Machine we had the same issue with had done less than 100k. Only seen it happen once so far. But more and more machines getting out there. Handy to keep a spare clutch just in case.
              • 22943
              I've been reading about this clutch on various other threads. Sounds like something I should keep on-hand. =^..^=
              • acusso1234
                Tecnico
                • Dec 2008
                • 250
                A0EDM20000 clutch
                ... In the minute that you're thinking of giving up, think about why you lasted so long ...
                • sauce_boss
                  • Oct 2011
                  • 26
                  Put the clutch in CL6 and it took care of the problem right away. Thanks for all the help.
