Jagged scan lines through ADF C352
  • paulrid
    • Nov 2011
    • 206
    Hi all,
    First off I hope this makes some sense.
    When I print a lattice pattern all the lines are square and when I copy if off the glass they are also square but when I copy it through the ADF the vertical line about the 5th square down is jagged. Also the square 3 from the bottom is not straight. All the rest seem o.k. Any ideas?
    Thanks in advance Paul.
  • kingarthur
    • 1367
    Re: Jagged scan lines through ADF C352
    Carry out the height adjustment on the RADF as per the manual...
    • paulrid
      • Nov 2011
      • 206
      Thanks for the reply I'll give it ago.
