Touch panel C252
  • keller34
    • May 2025
    [Misc] Touch panel C252
    I have a c252 that the touch screen was working just fine a few minutes ago and now when you press one area it acts like you pressed another spot. Tried the touch screen ajustment and could only touch the bottom 2 crosses. Everything else works an dnow errors are showing.
    I had this happen before and fixed it but cannot find my SM to do it again nor can I remember how by memory.
    I do know it was not in the Touch Panel Ajustment. It was in Service mode I do believe. Damn my bad memory!
  • Darren King
    copiertech
    • 652
    Re: Touch panel C252
    Your touch screen is failing and you need to have it replaced. It is a known issue with these machines.
    Hope this helps.
    Darren
      • 22942
      It doesn't matter about the touch panel adjustment. It won't hold for any length of time, anyhow. Just replace the tablet. =^..^=
      • keller34
        well thank you for this...I was afraid of that as I read many threads saying that it is a problem. I got this for free a few months ago. So would anyone say it is worth fixing? I prints fine as is and I only use it once in a while.
          • 22942
          Sure it's worth fixing. Eventually you'll need access to more advanced features or service mode, and the failing panel will block you from doing either. =^..^=
          • big jase
            • Jul 2008
            • 136
            there is a fix you can try ,i done this a few times , split the touchscreen and hold a lighter all around edge of t/screen........may sound strange but works!
            If at First you don't succeed remove all evidence of ever trying!
            • keller34
              Thanks..I tried the heating it and it wored but I found a heck of deal on a new panel and ordered it for when this one goes.
              I thank every one for the help and have another issue that I will make a new thread for.
              • Synaux
                • Mar 2012
                • 1224
                I wonder...does a C252 have a serial port connector (scrolling through the pictures in the service manual I am pretty sure I can see one)?
                One might be able to access the service panel remotely by connecting a computer to it and using the software jig nonsense that is used for the C252Ps (a C252 without a screen/scanner--just the printer).
                I doubt Konica would have intentionally blocked access or make any rudimentary changes to the system code to not allow this. Then again, what do I know.
