Konica copier 1503 ZMR
  • Don Komer
    Ihave a Konica 1503 copier which keeps showing a \"35\" fault. This fault is associated to the fixit heater temperature.
    When the fixit section test is run it checks just fine.
    I have checked all components on the fixit section separately and they all check that they are good. How do I clear the \"35\" fault?
    Don Komer (fixit@pixius.net)
  • CMB
    KonicaMinolta Tech.
    • Mar 2005
    • 457
    Re:Konica copier 1503 ZMR
    throw it in the dumpster. konica has not made parts for that copier in over 5 years.
    really, you are probably s.o.l. on that one if a thermostat is out
