The swing out duplex door rollers are clutch driven off the main drive unit - they used to have their own motor in previous versions of this engine, ie, c360 series.
If you find the duplex rollers simply don't turn when trying to duplex and you have consistent jamming at the top duplex roller - replace the duplex drive clutch in the rear of the machine.
Load check is a waste of time, because just a bit more current is delivered to the clutch in load check than in normal operation and it WILL lockup, making you pull your hair out wondering WTF is going on.
Fortunately, i have plenty of hair left.
