Hello tech's, The c-353 I'm working on is back grounding on the first page and first 4 inches of the leading edge only ( sample attached), after that it runs fine for that job. What it looks like to me is loosing developer bias. I pulled out the transfer unit and all the I/U"s and cleaned cavity well and pulled the cleaning unit from the transfer assembly and vacuumed the cleaning section for stray developer. I also replaced the black I/U, same problem. When the CQ problem happens the image under the background looks ok. any suggestions would be greatly appreciated. Thanks
sample 5.pdf
sample 5.pdf
