bizhub c353 removal of fuser unit
  • DOE
    • Mar 2010
    • 258
    sorry its the finisher i cant figure out how to remove
  • JustManuals
    • Jan 2006
    • 9838
    Re: bizhub c353 removal of fuser unit
    Paul@justmanuals.com
    • Toxic
      • 697
      Maybe this help.
        • 14754
        What model is the finisher? One of them has four screws that go through a plate on the finisher and fasten it to the left side of copier. The other one just has a bar that the finisher slides on and there is a long screw that goes through the bar to hold it.
        They are both pretty easy to remove.
        • Hansoon
          • Sep 2007
          • 3385
          I highly advise to remove the transfer belt unit before removing the fusing unit. It can otherwise be damaged very easily in the process.
          Hans
            • 14754
            Hans
            Why? The fuser clears the transfer belt by a wide margin.
            Besides, he corrected himself, it is the finisher he wants to remove.
            • Hansoon
              • Sep 2007
              • 3385
              Yap and still you can hit the belt with the fuser unit if you don't take care.
              Hans
              • PeterG
                • Jul 2008
                • 177
                Hans
                You must be doing it with your eyes closed Hans.
                • Hansoon
                  • Sep 2007
                  • 3385
                  Well, if you are in a hurry and if you have rheumatic pains in your hands and if the fusing unit is hot as molten lava and if you are suffering from a serious bout of dumbfuckness, than you might let the fusing unit slip out of your hands hitting the fuser belt causing a fat nick in it.
                  Ofcourse this all never happened to me. Ofcourse.
                  Hans
